25mil carb set up advise plz
Danger
Main scooter: lambretta TV200
looking sum advise on carb set up its a gp 200 stage 4 top end jl3 exhaust 25mil delly rubber mounted with remote filter engine internals are all tv200 the advice i got the other day was to use a d29 needle an aq264 atomiser and was given 3 main jets an 88 / 92 /95 clearly it didnt run rite so i put the aq266 back in with the 95 main its ten times better have orderd n aq268 an sum new jets rranging from 98 to 110 so any help on this wud be great thanks everyone
J1MS
I put one on with an AQ268 and D22 needle and a 105 main can't remember needle position
Or pilot jet But it might have been a 55. this was with a Taffy pipe and a filer through the air box.
Not quite the same set up, but I thought it might help.
Danger
thanks 4 your reply mine is 55 an needle sec clip i no not all set ups r the same if they were life wud be so much easier lol thanks again
Danger
looks like im gonna have to give the motorway sum abuse an sort this out on me own :frog:
