rearsets
I wanted to cut my running boards down, so needed somewhere to put my feet.
I used exhaust clamps from ScooterLoopyJohn fixed onto the engine mounts and then made some brackets from bits i had around the workshop.
I may have subliminally got the idea from looking at martinr's cutdown at wicksteed [and thanks to martin for sharing some pics of his work].
The position is fine [the left hand is slightly lower and offset more than the RH on purpose, just because there is nothing restricting it that side].
But I may need to change the actual pegs as getting a bit of vibration at certain revs. I used BMX stunt pegs which I had on a previous bike, but then remembered that that was for the pillion, so had never actually used them [no wonder the missus complained about numb feet when we rode to cornwall!]. Maybe i need to get some pegs with rubber on them...
I will do a few more miles and see how they are.
Next job is to finish off the running boards and fit some pillion pegs to the hangers.
Angry Bloke
Top job as always there Byron
:D cheers mate, speak to you later
MarkH
Nice!
I was just looking at making those exhaust mounts work in a similar fashion the other day. I think your vibration would be lessened by using a peg that is solid rather than hollow. Those billet ones can be had for cheap on ebay.
Nice work Byron 8-)
