28mm open mouth or through air box???
lammysilver
Originally I was going to run a 25mm dellorto through a modified airbox, to keep the standard look.
But ive managed to get my hands on a 28mm del for free.
So the build is continuing with this carb instead, its a SR175 with a clubman.
After advice on wether this can be run through the airbox to keep the original looks, or is it worth getting a ram air instead.
Thanks
soosh
As far as im aware,you wont be able to run it through the airbox so ram air it but i personaly would run it open mouth anyway.If you have the panels on,you wont see it.
rog60
Main scooter: Indian GP200
Got a 28mm on mine with ram air remote filter. Breathes much better, no problems except trying to get set up right :oops: :oops: :oops:
ForemanBob
Main scooter: GP RT230
I run my 28/30mm PWK on my SR175 through a ram air filter.....
works a treat, and the filter tucks into where the box would have been.
lammysilver
Foreman Bob, where abouts did you get your ram air set up from?
ForemanBob
PM Sent
    Users browsing this forum: Semrush [Bot] and 15 guests
