28mm open mouth or through air box???
lammysilver
Originally I was going to run a 25mm dellorto through a modified airbox, to keep the standard look.
But ive managed to get my hands on a 28mm del for free.
So the build is continuing with this carb instead, its a SR175 with a clubman.
After advice on wether this can be run through the airbox to keep the original looks, or is it worth getting a ram air instead.
Thanks
soosh
As far as im aware,you wont be able to run it through the airbox so ram air it but i personaly would run it open mouth anyway.If you have the panels on,you wont see it.
rog60
Main scooter: Indian GP200
Got a 28mm on mine with ram air remote filter. Breathes much better, no problems except trying to get set up right :oops: :oops: :oops:
ForemanBob
Main scooter: GP RT230
I run my 28/30mm PWK on my SR175 through a ram air filter.....
works a treat, and the filter tucks into where the box would have been.
lammysilver
Foreman Bob, where abouts did you get your ram air set up from?
ForemanBob
PM Sent
