intake manifolds
Tosh
got a little problem,i`m ready to see sean & dan this sat to set carb up but i`ve just found out that little prob,with hole in panel,ive just been down cul-de-sac and when i`ve got back and taken panel off i`ve noticed the corner of the float bowl is rubbing the inside of the panel.what options do i have
1.cut hole to more of an oval shape.2. put a shorter manifold on, could i do that after its been set up.
Paul
sounds like you may need to use a shorter manifold ,
i seem to remember that yours was maybe a solid mount one that had been shortened and modified by someone....but obviously not short enough... :D
we will still be able to dyno it though ,and you can change /modify it after...
Tosh
sean brady scooters wrote:sounds like you may need to use a shorter manifold ,
thanks for that sean i was worried i`d have to sort it out first and that would have been another week .
see you saturday 11.00am dans got me & brother booked in :)
Knowledge
The flanged rubber mounts are good for making a short inlet. Jimmers sells them, but you can try and pick one up from a bike breakers. The problem is that rubbers bought from a breakers don't always suit your chosen carb (the ridge might not be in the best place), but Jimmers buys them from a place (I can't remember the name, b ut someone will) where they do match the carb).
You have to machine the manifold to weld-on an ali flange, but these flanged rubbers always seem to save valuable millimetres. I've made two, one for my 190, and another for my 240 (still in bits)
Martin
Knowledge wrote:The flanged rubber mounts are good for making a short inlet. Jimmers sells them, but you can try and pick one up from a bike breakers. The problem is that rubbers bought from a breakers don't always suit your chosen carb (the ridge might not be in the best place), but Jimmers buys them from a place (I can't remember the name, b ut someone will) where they do match the carb).
Just to clarify, Jimmers ones are a straight fit and designed for TS1 ;-)
Knowledge
Quite right Sousurfer, but he will sell you a rubber if you want to make your own manifold. The point i wanted to make was that the flanged rubbers to save space and are less prone to failure/leakage.
Martin
Tosh
thanks soulsurfer/Knowledge,but i`ve never seen a flanged rubber mount ,even the ones that jimmers sells you couldn`t post a picky for me please. I`ve asked a gent opposite to my works who restores old motorcycles he put a 110rod into my crank webs,he said he would turn it down for me no probs.he`s under performance pushrods (mike pemberton) a very nice gent
