crank identification
westburyst
hi,
i have an early 90's indian gp200. i thought i had a gp crank but after inspecting the mag side bearing setup i found that it had a NU205 bearing fitted as well as the bearing distance piece?
what measurements or characteristics should i look out for to best determine what crank i have.
cheers
SIL GP200 92'
I've lost count how much I've spent.
Stokie
Sounds like the same configuration that Innocenti used on the GP150 (GP crank taper but NU205 bearing + spacer)
the sholder that the oil seal sits on will be either 10mm or 13mm the latter will only acept a 205 and is a 150 crank
westburyst
shocky,
the shoulder that you are referring to, is this where the bearing collar sits on?
if this is the case, i have measured it and it is 10mm. Also measured the crank pin and is 22mm and big end width is 15.5mm.
cheers
SIL GP200 92'
westburyst wrote:shocky,
cheers
its not were it sits on its were it butts up to , you have the crank cheek then the inner mag side oil seal journal then the flywheel spigot , its the journal that you measure should be 10mm or 13mm and 33mm wide ,as you have said the big end is 22mm so this dictates its a 200 crank as the ones with a 19.9mm pin are the 13mm journeled ones
rog60
Main scooter: Indian GP200
Should have a spacer in then to fit an NU205 bearing, remove spacer fit NU2205 bearing :?: :?:
westburyst
yep, that is what I actually meant. i did not describe it properly.
thanks..... :bouncing:
SIL GP200 92'
    Users browsing this forum: Google [Bot] and 37 guests
