Compression height on KH750 piston
J1MS
Uses 116 rod and packer plate to adjust deck height.
there is only one correct way of measuring comp height on pistons.............
that IS.........from gudgeon pin centre to crown edge................................
there is NO "new money"way.........thats ball.x................ :lol:
if you really considered things and thought it through properly you would realize that measurements done the "new money" way would not take into consideration gudgeon pin thickness etc.................
davidblythe wrote:Dan are you measuring from middle of the gudgeon pin at 39mm for Lammy piston ?
Is there any other way? :lol:
davidblythe
if 18mm gudgeon pin add one mm onto the new money number to get direct comparision with lammy piston
btw my mistake for not setting a reference point,
davidblythe wrote:if 18mm gudgeon pin add one mm onto the new money number to get direct comparision with lammy piston
Damn fangled 'new money'. :lol:
J1MS
davidblythe wrote:
J1MS wrote:Compression height 32mm is correct. Top Of the class Sean
so 24mm in new money
Is that euro's :?: sounds good to me :!:
Ian Hepworth
sean brady scooters wrote:there is only one correct way of measuring comp height on pistons.............
I concur.
;) :lol:
davidblythe
I shall plough my own furrow, as adding a 1 onto a number is quite easy :lol:
seriously thou its far easier to measure the height with a gudgeon pin half in the piston than guessing where the centre of the hole is, only my opinion
davidblythe wrote:I shall plough my own furrow, as adding a 1 onto a number is quite easy :lol:
Sounds like a 'fudge factor' for half a job! :lol: :lol: :lol:
