Compression height on KH750 piston
Uses 116 rod and packer plate to adjust deck height.
- sean brady scooters
- Dealer
there is only one correct way of measuring comp height on pistons.............
that IS.........from gudgeon pin centre to crown edge................................
there is NO "new money"way.........thats ball.x................
if you really considered things and thought it through properly you would realize that measurements done the "new money" way would not take into consideration gudgeon pin thickness etc.................
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
Is there any other way?davidblythe wrote:Dan are you measuring from middle of the gudgeon pin at 39mm for Lammy piston ?
davidblythe
if 18mm gudgeon pin add one mm onto the new money number to get direct comparision with lammy piston
btw my mistake for not setting a reference point,
- drunkmunkey6969
- Moderator
Damn fangled 'new money'.davidblythe wrote:if 18mm gudgeon pin add one mm onto the new money number to get direct comparision with lammy piston
davidblythe wrote:so 24mm in new moneyJ1MS wrote:Compression height 32mm is correct. Top Of the class Sean
Is that euro's
Ian Hepworth
I concur.sean brady scooters wrote:there is only one correct way of measuring comp height on pistons.............
there is NO "new money"way.........thats ball.x................![]()
- Dealer
davidblythe
I shall plough my own furrow, as adding a 1 onto a number is quite easy
seriously thou its far easier to measure the height with a gudgeon pin half in the piston than guessing where the centre of the hole is, only my opinion
- drunkmunkey6969
- Moderator
Sounds like a 'fudge factor' for half a job!davidblythe wrote:I shall plough my own furrow, as adding a 1 onto a number is quite easy
