Compression height on KH750 piston
davidblythe
Can anyone tell me the crown and dome height on this piston
32mm compression height i think
davidblythe
cant be right, a 116mm rod is used with them possibly 22mm
davidblythe wrote:cant be right, a 116mm rod is used with them possibly 22mm
If a Lambo is 39mm on a 107 rod...then a KH must be approx 30mm on a 116 rod?
Sean wont be far off....? 22mm is a bit whacky though?
I believe (from my incredibly bad memory) that they are actually 31mm to be honest...but will stand corrected if anyone says different?
J1MS
Compression height 32mm is correct. Top Of the class Sean
J1MS
davidblythe wrote:Can anyone tell me the crown and dome height on this piston
I would have to measure one of mine, as I cant remember profile height.
davidblythe
crown height measured from top of gudgeon pin to edge of piston crown
prefer this definition as the piston catolgue i have use this (unfortunately doesnt include H2 piston)
davidblythe
drunkmunkey6969 wrote:If a Lambo is 39mm on a 107 rod...then a KH must be approx 30mm on a 116 rod?
Dan are you measuring from middle of the gudgeon pin at 39mm for Lammy piston ?
davidblythe
J1MS wrote:Compression height 32mm is correct. Top Of the class Sean
so 24mm in new money
    Users browsing this forum: Semrush [Bot] and 0 guests
