Compression height on KH750 piston
davidblythe
Can anyone tell me the crown and dome height on this piston
- sean brady scooters
- Dealer
32mm compression height i think
davidblythe
cant be right, a 116mm rod is used with them possibly 22mm
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
??davidblythe wrote:cant be right, a 116mm rod is used with them possibly 22mm
- drunkmunkey6969
- Moderator
If a Lambo is 39mm on a 107 rod...then a KH must be approx 30mm on a 116 rod?
Sean wont be far off....? 22mm is a bit whacky though?
I believe (from my incredibly bad memory) that they are actually 31mm to be honest...but will stand corrected if anyone says different?
Compression height 32mm is correct. Top Of the class Sean
davidblythe wrote:Can anyone tell me the crown and dome height on this piston
I would have to measure one of mine, as I cant remember profile height.
davidblythe
crown height measured from top of gudgeon pin to edge of piston crown
prefer this definition as the piston catolgue i have use this (unfortunately doesnt include H2 piston)
davidblythe
Dan are you measuring from middle of the gudgeon pin at 39mm for Lammy piston ?drunkmunkey6969 wrote:If a Lambo is 39mm on a 107 rod...then a KH must be approx 30mm on a 116 rod?
davidblythe
so 24mm in new moneyJ1MS wrote:Compression height 32mm is correct. Top Of the class Sean
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Semrush [Bot] and 23 guests
