EGT advice needed...
Nic
I'm about to order one. I was thinking of one of these two, which a few people have already recommended:
http://www.ekmpowershop2.com/ekmps/shop ... 2803-p.asp
or
http://shop.airworlduk.com/egt-gauge--r ... 2-23-p.asp
Any comments? Ironically, the slightly cheaper one looks like it has a better display. Just wondering if either can be backlit in the dark.
Also, any ideas as to what exhaust sender to use?
Many thanks, Nic
Hi Nic,
They are in fact the same guage, different face, I have both types, I got mine here... http://www.skydrive.co.uk/search.asp
You can use the clamp on or screw in, the screw in requires welding but the clamp on works fine too ;)
Nic wrote:I'm about to order one. I was thinking of one of these two, which a few people have already recommended:
or
Many thanks, Nic
Im really shocked how cheap these are, can you get the sender cheap as well.?
Diablo
Chris Sturgess was telling me he had had a couple of these fail and didn't rate them-perhaps why they are so cheap?
soullad
was it the senders that failed? If so the clamp on sort or the weld in?
tha83
Main scooter: SX 2something
Nic, the second one from airworld is made here in Cali by Westach and they are good EGT's. Vibration will kill it though and I' had to send mine back and the lead tech and designer took it apart and loctited some stuff for me. 5,000 miles and counting of some hard riding.
Nic
Cheers guys. I eventually went for soulsurfer's one, which is the same as the Airworld product but a bit cheaper. Thanks also to Mark for his separate suggestion...
Diablo
Yes I think it was vibration but I'll ask him what his solution was.
cryogenic
Hi Nic i use the KOSO one from cam lam and done thousands of miles with it and have absolutely no probs with it its blue backlit and goes red if over temp is activated easily readable great bit of kit.
I RAN OUT OF SICK DAYS SO I DECIDED TO RING IN DEAD
DJB
cryogenic wrote:Hi Nic i use the KOSO one from cam lam and done thousands of miles with it and have absolutely no probs with it its blue backlit and goes red if over temp is activated easily readable great bit of kit.
Have you any pics or links
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
