Regarding this topic is there a step by step idiots guide to doing this as i'm looking to go down this route too...
just don't want to feck my stator or pod/wassel unit up..
if its already on here, then apologies for being dum......
Yes, it would connect in the same way as a standard vespa reg, leaving the B+ connector to feed the battery positive, earth the battery -ve and run accessories off the +ve via a fuse.Spud wrote:Would that just replace my existing regulator & connect into the loom & just connect the battery to the reg?
which is what I'm in the middle of fitting to mine. and also keeping the Minarelli rectifier I have been using for my tacho; so will end up with an AC circuit [for the standard lights], some battery DC charged from the vespa unit [for the horn, phone charger, any other accessories, maybe a spotlamp?] and rectified DC from the Minarelli [for my tacho], which is possibly over complicating it, but should have some options if something fails, and it's on my bike so i know what it's all for... In my recent rectifier tests a genuine Ducati P2 unit gave the best voltage readings.firekdp wrote: Yes, it would connect in the same way as a standard vespa reg, leaving the B+ connector to feed the battery positive, earth the battery -ve and run accessories off the +ve via a fuse.
Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 8 guests
