Ts1 running rough
craig69
Hi all, just took the scoot out for a run, and it is running really bad between closed and quarter throttle when trying to accelerate but fine all the way through the rest of the rev range. If i knock the choke on it runs great,so i presume its running rich upto quarter throttle ? Any idea's guys.
Ts1 225
35mm tmx. main 330, needle 56 top notch, pilot jet 22.5 and standard slide
Ramair filter
Jl3 pipe
DJB
1)Check your plug, if running round town it should be a B8
2)Take your air filter off
3)Try a 20 pilot
Start at these and see how you get on.
You could always try one of these two
http://www.thunderproducts.com/IntelaJet.htm
http://www.thunderproducts.com/dial_a_jet.htm
gaz_powell
was it running okay previously?
carb settings seem okay
sounds like blocked jets - carb off and a thorough clean through would be the first job
DJB
It wouldnt feel rich if the jet was blocked, it would pink.Or is it pinkin?
Atmosphere is the more likely if it was rich.
I think you need to determine weather its rich or lean. If its lean then it will feel like its missing and may rev high. If its rich it will feel like its boggin down.
camel
easiest first....plug is a favourite....and possibly reeds
Knocking the choke on would richen the mix suggesting it's weak without choke.
J1MS
corrado wrote:Knocking the choke on would richen the mix suggesting it's weak without choke.
That's what I thought.
craig69
Cheers chaps thats gave me some things to look at tomorrow.Would the air screw richen the carb up enough ?.
And thanks Corrado and J1MS for putting me right on how the choke system works (must have been havin a blonde moment) :oops: .
craig69
Just a quick update, stripped the carb and cleaned it out , set the airscrew to 1 turn out and its running great now upto half throttle but then seems a little boggy upto full throttle but nothing i cant live with at the minute.
So thanks again to all who posted and gave help. Cheers Craig
    Users browsing this forum: Ahrefs [Bot], Baidu [Spider], Semrush [Bot] and 7 guests
