Improving a piston: porting, polishing...
Avantone
Fred_64 wrote: For psychiatrists, here is my little workshop….
Are you James May?
Tony
www.lambrettagearbox.com
Fred_64
Are you James May?
Well… I used to work with Jason Dawe (Top Gear 2002), that is how close I will ever be from James May, probably…!
Did you know you could polish dampers as well??
lighter and cheaper than chrome... lasts 3 to 4 days depending on weather conditions.
shorten the sleeves, I am not a Gorilla...
fred,
you say a TS1 piston weighs 336 grams..
was that WITH piston rings,gudgeon pin ,clips and maybe small end bearing...?
red ghost
Main scooter: lambretta gp150
What's the ideal width and angle for a chamfer on the outside of the skirt?
10/15 degrees and 2mm
others may do it slightly different,but so long as you have some sort of chamfer on there as opposed to a sharp square edge,it will help lube....as the square edge scrapes oil off.
leigh
Fred_64 wrote:
Are you James May?
you sure you aint on that programme how clean is your home.
Leigh
Fred_64
fred,
Sorry I was away; YES, it was including everything (even the plastic bags), and it was slightly over 336 gralms; 339.49
This is a good unit; it tells you the difference between a 72 main jet and a 75 main jet; 0,03 gramms :shocking:
72 jet:
75 jet:
There is a very fine line between "hobby" and "mental illness".... :lol:
whats the point in weighing main jets.... :?
its the flow rate that counts.
next you,ll be weighing bulbs to compare with wattage :lol:
red
sean brady scooters wrote:There is a very fine line between "hobby" and "mental illness".... :lol:
PMSL :biggrin: :biggrin: :biggrin:
MEOW :lol:
    Users browsing this forum: Baidu [Spider] and 10 guests
