sx headstock
stuart rimmer
can anyone tell me the diameter of the steel bar that is fitted in to both sides of the headstock for throttle and gearhousing to fit onto as my gear side has snapped and needs a peice welding thanks
rog60
Main scooter: Indian GP200
stuart rimmer wrote:can anyone tell me the diameter of the steel bar that is fitted in to both sides of the headstock for throttle and gearhousing to fit onto as my gear side has snapped and needs a peice welding thanks
Do you mean the steel tubing that projects from the ends of the handlebars :?: :?: :?:
stuart rimmer
yes mate the steel that is fitted into headstock looks like handlebars when you take everything off the headstock
22mm
stuart rimmer
thanks mate , now where to get some 22mm tube from anyone
most enginering workshops would be happy to sell you some
rog60
RICSPEED wrote:most enginering workshops would be happy to sell you some
And splice a piece on the end to replace the damaged bit. Had that done on a S3 gear support that had rusted badly at the end.
    Users browsing this forum: Google [Bot] and 7 guests
