Any Thoughts On This?
100mphlambrettaclub
lubrication problem me thinks,i hazzard a guess that there is excesive ring ware as well
cezeta
on the spiggot side of the inlet there is a white line, is this a camera oddity or is it wher ther is no plating. i was wondering if the shamfer has exposed the ali enough for the two ali matirials to rub?
cezeta wrote:on the spiggot side of the inlet there is a white line, is this a camera oddity or is it wher ther is no plating. i was wondering if the shamfer has exposed the ali enough for the two ali matirials to rub?
Not sure where you mean. The line you can see running left to right around the bottom of the inlet is the chamfer, it's quite large but I assume this is okay as this cylinder hasn't been touched by anything other than capable hands.
Image Image
This cylinder has done a few thousand miles now, it had a new piston fitted recently. I also fitted a new carb, after a short while I thought I had piston slap, although I'd done a couple of hundred miles with this piston prior to changing carb. The egt guage highlighted a lean spot when cruising and I assume this is where the lack of lubrication caused the damage?
100mphlambrettaclub
what fuel was you using,hats the exhaust side like.
Unleaded from the local Total forecourt. No damage on exhaust sidenits all clean apart from what you can see in the pics, rings look fine too.
rbgaz
this usefull info for lookin for cause of piston falure
https://www.slipstreamperformance.com.a ... Path=4_567
Jet200
Good link rbgaz. Very interesting 8-)
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
