ware were they fromrog60 wrote:Bloody hell mate, they're better than my 'made as original' links.![]()
Fork Links
- rog60
- registered user
- Main scooter: Indian GP200
- Contact:
Dunno, were on scoot when I bought it, probably Viet. Although had no problems and seem strong...........................shocky wrote:ware were they fromrog60 wrote:Bloody hell mate, they're better than my 'made as original' links.![]()
- Monty
- registered user
- Main scooter: Series 1 Muggy, Imola Special
- Contact:
Just had a set back from Shocky. The quality of his welding is top notch, plating is great. So much better doing this than useing those bloody bolt on plates
Thanks Shocky
Monty
Thanks Shocky
Monty
sydduckett
- registered user
- Contact:
Steves got my set and hopfully back for next weekend then the re-build can start again...
- carlos fandango
- registered user
- Contact:
Ive had some from shocky as well
and i can highly recommend
He's also been known to convert the odd shock or two .....
well recommended. Pm sent mate.
i wouldnt say it was but frank sanderson had some welded and dropped one the lug just cracked off also when the links have been fitted the end were the hub goes has snapped offStampede wrote:why is the welding impossible for indian ones?byron wrote:as long as your links are Italian or Spanish
Shocky is the man for the welding
if you have a set and want them welded i can do it no problem i suspect they would be ok on a standard machine
if i did some and they broke i would loose some of the faith others put in my work i always try and resolve any problems of anything i supply im not a dealer just do a few things in my spare time and if there is a prob i usually take a hit
storkfoot
- registered user
- Main scooter: '70 GP150 [TS1 225]
- Contact:
The quality of the metal is not as good which makes the links wharp when welded.Stampede wrote:
I've had 3 sets of damper mounts welded to Italian links with no problems. The one set of Indian ones I had welded looked OK, however, they wharped and sent the fork links out of plane. Definitely avoid welding Indian links
