Fork Links
rog60 wrote:Bloody hell mate, they're better than my 'made as original' links. :o :o :o
ware were they from
rog60
Main scooter: Indian GP200
ware were they from
Dunno, were on scoot when I bought it, probably Viet. Although had no problems and seem strong...........................
Monty
Just had a set back from Shocky. The quality of his welding is top notch, plating is great. So much better doing this than useing those bloody bolt on plates
Thanks Shocky
Monty
sydduckett
Steves got my set and hopfully back for next weekend then the re-build can start again... :D
carlos fandango
Ive had some from shocky as well :D and i can highly recommend :D :D
soullad
He's also been known to convert the odd shock or two ..... :lol: well recommended. Pm sent mate.
colski
Playstation gamer tag: colski
Thanks for your posts guys. I have PM shocky and will be sending him mine to do.
Col :mrgreen:
Lets do It Sat Down....
Stampede
Main scooter: SX200
byron wrote:as long as your links are Italian or Spanish
Shocky is the man for the welding
why is the welding impossible for indian ones?
i wouldnt say it was but frank sanderson had some welded and dropped one the lug just cracked off also when the links have been fitted the end were the hub goes has snapped off
if you have a set and want them welded i can do it no problem i suspect they would be ok on a standard machine
if i did some and they broke i would loose some of the faith others put in my work i always try and resolve any problems of anything i supply im not a dealer just do a few things in my spare time and if there is a prob i usually take a hit
storkfoot
The quality of the metal is not as good which makes the links wharp when welded.
I've had 3 sets of damper mounts welded to Italian links with no problems. The one set of Indian ones I had welded looked OK, however, they wharped and sent the fork links out of plane. Definitely avoid welding Indian links
    Users browsing this forum: Ahrefs [Bot] and 5 guests
