Copper Sandwich Exhaust Gaskets
Rumaging through my bits and pieces I came across a couple of copper sandwich type TS1 exhaust gaskets, are these worth using or should I cast them aside?
I'd use them but I wouldn't 're-use' them.
leigh
these are the only ones i personally like, and agree would only use once
Leigh
YAMLAM
does any body do a solid copper one,i still use( for standard exhaust ) one i got from webbo (MSC ) back in the 80`s,just heat it up with a blowtorch untill it`s cherry red then dunk it in water.
win or lose have a booze
goldeneye
soulsurfer wrote:Rumaging through my bits and pieces I came across a couple of copper sandwich type TS1 exhaust gaskets, are these worth using or should I cast them aside?
use gilera runner exhaust gaskets, same and cheaper. once you mention TS1 on the fone , the till starts ringing faster at most dealers.
goldeneye wrote: use gilera runner exhaust gaskets, same and cheaper. once you mention TS1 on the fone , the till starts ringing faster at most dealers.
TS1 gaskets are about £1.40, just googled Gilera runner exhaust gaskets, 1st two I looked at were £3.39 and £1.96, so I'll agree to disagree with you.
goldeneye
your not a dealer are you by any chance............... :roll:
Yes, so point me in the direction of the 50p Gilera gaskets. :roll:
goldeneye
back of the net! is that a bite? :D
Booby
Could be a bit rough on the old teeth
Who holds the scooterotica Key.....Dan does! ;0)
