Worst Job on A Lambretta..............Grrrrrrrrrrrrr
rog60
Main scooter: Indian GP200
Renewing the rear hub oilseal............
I warm the seal then try to tap it in evenly using a drift that rests on the flat part of the seal.
Trouble is, it never seems to sit properly when fitted, looks like the oil seal lip has turned out on itself a little, although the seal lip is on the inner face of the bearing. I just know this seal is gonna leak......................
There must be a better way.
Using Rolf seals by on an SIL 200 engine bythe way.
mickyb
get a stiff piece of plastic long enough to bend into a cylinder the same size as the inner bearing race, put it through the oil seal, leberally cover in oil, then place the plastic cylinder over the inner race and push the seal into place then withdraw plastic, job done :D
rog60
Brilliant and devilishly simple......will try that tomorrow. Thanks :bouncing: :bouncing:
paulmgreen
Yes..... i'd agree . rear hub oil seals are a pain! deffo amongst the worst jobs
one more is removing / refitting the mag flange wiring plate
www.JPPLambretta.co.uk
drive side oil seal a right cnut lots of room for braking other things
tony
Main scooter: 90ss
And I always thought the worst job on a lambretta was pizza delivery ;)
Train Driver
Worst job must be having to talk to the mechanic when you drop your scooter off for some workshop time :D :D
or even having to take it there, what's wrong with home pick up ;)
rog60
6LDA 28B wrote:Worst job must be having to talk to the mechanic when you drop your scooter off for some workshop time :D :D
Got pick up around here cos the workshop is about 15 miles away, but the cost is always factored in.
rog60
shocky wrote:drive side oil seal a right cnut lots of room for braking other things
It started out as a rear brake adjustment cos MOT tomorrow, found out no more adjustment. Change brake shoes, take hub off and very slight seepage of oil onto brake shoes. Dig out old oil seal (Indian but 4000 miles on it). New Rolf seal very tight, warmed in hot water, still won't go on eventually did but doesn't look quite right. Put new shoes on, slacken cable at pedal for adjusting, hub very tight on new shoes.......................feck, it just goes on.............. :roll: :roll: :roll: :roll: :roll:
rog60
tony wrote:And I always thought the worst job on a lambretta was pizza delivery ;)
Naw, round here they use Vespas :lol: :lol: :lol: :lol: :lol:
    Users browsing this forum: Google [Bot], Semrush [Bot] and 21 guests
