Sh*t Front Brake.
johnny diamond
this is why we wore oxford bags in the old days if you stuck your legs out they acted like parachutes :roll:
and platform shoes were not a fashion item....we just new we could get a good few emergency stops out of them before they
needed replacing :D
Booby
Get yourself a parachute just incase of emergency stops Bic
Who holds the scooterotica Key.....Dan does! ;0)
Dazza
Lui wrote:Try reverse pull cables, we use that method for stock class racing in the U.S. and it works great, also sanding your pads and blasting or sanding your hub inner.
I thought there was a negative/dangerous reason not to carry out this mod ondrum brakes Lui?
Lui
Never heard of such a tale with the conversion
EID
Bic are you sure your pulling the right lever?
Soulpunk
cheap very good brake:
buy a new sil indian gp front brake hub and "makino" brake shoes (ebay).
the "makino" brake shoes cost half of italian ones (about 7,90) and have a lighter colour.
get a new gp cam and any good condition backplate.
result: very very good braking.
(tested now 8 of these brake-setups. every one works very very good. no fading, very powerful. like a very good vespa p-range II font brake)
bicboy
Main scooter: S2, EID Built, Diablo tuned...
Thanks for all the advice both serious and the quality funny ones :D bic.
Everything must be done to the Extreme.....
kejj
I've used the dremel to cut out 3 or 4 diagonal lines on the brake shoe padding.
Helped get a better grip. Although I only did it on the rear brake.
________________________
http://tv175.wordpress.com/
    Users browsing this forum: Semrush [Bot] and 8 guests
