sil 200 barrel options
cezeta
i have a sil 200 barrel, af 58mm crank (none twisty type) 25mm delly and clubman
it needs a piston.
sx200 casings and gearbox
what piston should i use, also if i widen the exhaust, how far should i go?
anything else worth doing while the dremel is out?
C*NTSPEED
i got a chrome asso one in my 200 pal
GEMINI S.C.
BLACK WIDDA'S S.C.
MarkH
race-tour piston
chamfer those ports
bazman
Mahle 2 thin ring cheap as chips but lasts fine, why spend 3 times as much on fancy forged type when this will do the job perfectly well , don't believe , don't believe, don't believe the hype ooooh yeahhh!!!
And get Mr Brady to port and match everything and it'll be sweet 8-) ;)
bazman wrote:Mahle 2 thin ring cheap as chips but lasts fine, why spend 3 times as much on fancy forged type when this will do the job perfectly well , don't believe , don't believe, don't believe the hype ooooh yeahhh!!!
I am..where do you get the mahle from bazman.I would imagine mine has the standard indian 3 ring..
bazman
Got mine from Andy Francis , let me know if ya want one and i'll see if he's any in stock , will be there on monday as i've an old norrie kerr tuned lardy lump to rebuild for him. :)
Yes please matey that be good..
bazman
Lam46 wrote:Yes please matey that be good..
Standard bore ? If you're at Brid Andy will be there trading , tell him i sent ya ( prob charge ya 2times as much though :lol: )
I am..cheers Baz
Lui
Open and lower the transfers, clean the transfers and chamfer the ports
    Users browsing this forum: Majestic-12 [Bot] and 15 guests
