ORIGINAL LOOKS, HI-TECH: 6V MICRO-RECTIFIER
Soulpunk
some folks posted this in a german scooterforum and i think its a top tip and far too good to be missed for english speaking lambrettisti:
6V battery-system and troubles with your original rectifier ?
get a modern kokusan rectifier. electronic and very small it fits in every series 3 or series 2
rectifier-box and works perfectly.
price: about 15.- gbp
you can get this for example via: http://www.zundapp.com
Werner Amort
the rectifier on the pic is from a varitronic and 12v
the kokusan rectificer is a little bigger, but it works...
That doesn't look as neat as the one J1MS renovated and posted up on here a while back....It involved a Maplin rectier.
firekdp
But this one is wired specifically for the varitronic stator.
Captain Chaos
Just a thought, but is there a possibility of that little regulator getting rather hot once the other half of the original box is fixed back in place????
Never really checked a regulator to see if they get that warm, but the aluminium finning makes me think that it's good to have air flow over them...
I'm probably completely wrong..... I usually am. :D
firekdp
You're probably right, on the original 60's conversion they drilled holes all around the box and later decided that the rectifier would be better outside (exposed).
Werner Amort
i have mounted a 6v kokusan rectificer in the orginal plastik box, an it´s working realy good in my s2 with battery an orginal loom
http://www.germanscooterforum.de/index. ... &p=1691434
    Users browsing this forum: Ahrefs [Bot] and 1 guest
