Small End Bearings Gap
You need the 16x20x22mm bearing
- Main scooter: LI150
Ok thanks.
I rang PM as I had got the crank from them, but the chap I spoke to said it's to do with the piston type supplied. I've measured the gap in the piston and it's almost 24mm. So would I still need to shim the piston?
Is it a Yamaha Blaster piston..??
Ive seen a couple of RB250 barrels using single ring Bultaco pistons...
bilko had exactly same thing on my ts1 (still in current engine )and i was told by af it dont matter as long as the big end is shimmed after all where is it going to go .my concern was about uneven wear but was told not to worry about it ,tis the first time ive ever had a piston like this .
andy
andy
- red
- Main scooter: Scomadi TL 250 (Ltd Ed No.3)
I'm sure between us we could find some way to fill the gap
