Small End Bearings Gap
Bilko
Main scooter: LI150
There's a gap of approx 3mm here. Is this ok without shimming?
Bilko's Oily Blog
MarkH
You need the 16x20x22mm bearing
Bilko
Main scooter: LI150
Ok thanks.
I rang PM as I had got the crank from them, but the chap I spoke to said it's to do with the piston type supplied. I've measured the gap in the piston and it's almost 24mm. So would I still need to shim the piston?
Bilko's Oily Blog
J1MS
Is it a Yamaha Blaster piston..??
Bilko
Main scooter: LI150
No Jims.
It's for the RB250 Not sure of piston type. :( :oops:
Bilko's Oily Blog
J1MS
Ive seen a couple of RB250 barrels using single ring Bultaco pistons...
Bilko
Main scooter: LI150
2 rings on mine.
How embarrassing not knowing the piston. :oops:
Bilko's Oily Blog
andylaw7
bilko had exactly same thing on my ts1 (still in current engine )and i was told by af it dont matter as long as the big end is shimmed after all where is it going to go .my concern was about uneven wear but was told not to worry about it ,tis the first time ive ever had a piston like this .
andy
Bilko
Main scooter: LI150
Would it not cause uneven wear on the small end bearings as theres quite a bit of space for them to move sideways?
Bilko's Oily Blog
red
I'm sure between us we could find some way to fill the gap ;) :D
