LAMBRETTA DYNO GRAPH POSTING AREA
Post your Lambretta dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
Norrie Bodge
Fruitjuice wrote: ↑Tue Apr 26, 2022 8:49 am Monza '240'
Barrel bored to 71mm with an H2 Wiseco piston
Touring tune by Powolotti
TMX30 carb
Short inlet manifold
60/116 crank
Adspeed ADS3 exhaust
16/46 with an Indian GP200 gearbox
LTH 7-plate clutch with uprated springs
What’s your jetting on this please?
Fruitjuice
I would need to check the idle jet, it's been in there over 7 years
Main Jet is 310
Power Jet blanked off
Std Needle/Atomiser
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
Fruitjuice
Keep in mind I'm still running this thing in so I might up the Main jet when it has some more miles on it after a couple of plug chops. Can't afford to do any full speed runs at this time
