TUNED AVANTI TT3 30+
Post your Lambretta dyno graphs here! But graphs & spec info only, keep the chat in the 'dyno chat' section ;o)
CANbus
Sat Oct 01, 2016 5:43 am
I'm going to get my avanti scoot on the road after two years, only change I have made before it was moth balled was to increase the squish from 0.9 to 1.3. I could never get any color on the plug. I'm hoping the squish change will help? watch this space.
11111111 = 0xFF
Lambretta Sash
Main scooter: Lambretta TV 230
Sat Mar 02, 2019 10:24 am
Update 2019 The avanti is still running well, not touched engine since last update and ran 85mph on dyno at Mersea 2017 to show its still got it
Mon Mar 11, 2019 4:34 pm
Certainly did run well and put mine to shame Sash :oops:
Sat Apr 27, 2019 4:16 pm
Sounds like it would put mine to shame too (not hard though as mine is 'off the shelf')!
Ooh, to have a look around the barrel and to see what DT and Sash have done to it... :mrgreen:
shamrockexpress
Fri Jan 08, 2021 12:55 pm
I have had an Avanti sitting on the shelf will start a build soon,,,,,,,,,it wil be going into a touring tv2 so i want RELIABILITY as top of the wish list so open to suggestions from the avanti men who have tried and tested :D
Kit will be standard i,m looking a cruiuser and keen to implement this using the RM box pipe.....
so what ignitions, gearing, carb, crank etc.......
look forward to replies
regards Shamrockexpress :D
ebay user ID: sc00terotica
Sat Jan 09, 2021 12:10 pm
30mm Delly, 4.6 gearing, DT 60/62mm crank, AF 6 plate clutch, SIP Vape Static ignition set at 17 degrees.
K.I.S.S.
shamrockexpress
Sun Jan 10, 2021 2:29 am
Keeping it nice and simple which is the hole idea, thanks.
anybody else want to throw their hat into the ring :-)
