Found this in gearbox oil...
deffo chain bits !
weedodger
Main scooter: Indian gp casa 185 and 200
sean brady scooters wrote: Tue Sep 17, 2019 1:13 pm deffo chain bits !
After having 2 engines done by Dan and you.. After I have a look here.. I might send this one down to you too.. Driving down from. Forfar and back was a pain :D
Scooterdude
weedodger wrote: Tue Sep 17, 2019 8:50 am
Scooterdude wrote: Tue Sep 17, 2019 5:53 am Yes definitely looks like chain roller shells. Full strip down required.
Barrel piston and head too... Or just the chaincase?
no not top end just chain case.
If it were me though I’d strip everything out including the gearbox and clutch and wash all the components and swill the whole inside with paraffin.
Have a good look at your chain, is it made by Rolon by any chance? If it is they are shite and should not be used, go for something decent like Regina for around £30 or if you must an Iwis for around £40.
weedodger
Update.. Casing off.. Think iv found the problem.. Think its a rolon chain.. Can't make it out.. But looks stamped on every link.. And one of the roller covers?? Is thinner than the rest.. Looks like that's the culprit..?
Now.. What link is the chain.. Is it easy to come off.. Anything else I can do simply whilst in here... And when putting new gasket on.. Just straight on? (lambretta upgrade thicker gasket) hope the pics are OK..
https://www.flickr.com/photos/184484635 ... res/825wC5
weedodger
weedodger wrote: Tue Sep 17, 2019 3:48 pm Update.. Casing off.. Think iv found the problem.. Think its a rolon chain.. Can't make it out.. But looks stamped on every link.. And one of the roller covers?? Is thinner than the rest.. Looks like that's the culprit..?
Now.. How do you determine what link is the chain.. 80.81...82...Is it easy to come off.. Anything else I can do simply whilst in here... The 3 broken pieces fit to make a perfect cylinder.. Don't think I will be looking for any other debris...??? And when putting new gasket on.. Just straight on? (lambretta upgrade thicker gasket) hope the pics are OK..
Scooterdude
Put a thin smear of grease on both sides of the gasket when rebuilding. Yes definitely a rolon chain.
weedodger
If iv 40 links on chain. I take it its an 80 link?
Scooterdude
weedodger wrote: Tue Sep 17, 2019 6:06 pm If iv 40 links on chain. I take it its an 80 link?
yus.
    Users browsing this forum: No registered users and 62 guests
