Found this in gearbox oil...
weedodger
- registered user
- Main scooter: Indian gp casa 185 and 200
- Contact:
Not long bought this lammy.. Not ridden yet... Decided to do oil change tonight... And change the chaincase gasket.... This popped out along wi the oil... Nice oil otherwise... Its metal.. Or alloy.. Not sure.. It pieces together like this.. Is about 8mm high and 6 to 8 mm wide... What the hell can it be.. Any ideas folks... I don't wanna ride the scoot on finding this....
weedodger
- registered user
- Contact:
Pic 2 of debris in oil...
https://www.flickr.com/photos/184484635 ... res/2o3f90
Anyone any idea what this thing was... Is...
- Toddy
- registered user
- Main scooter: Lambretta Series 1
- Contact:
Cant really tell how big they are ? are they Drive Chain Shells or part of a bearing ? Have you had a look inside yet ?
Scooterdude
- registered user
- Main scooter: Lambretta LI 125 S3
- Contact:
Yes definitely looks like chain roller shells. Full strip down required.
weedodger
- registered user
- Contact:
Barrel piston and head too... Or just the chaincase?Scooterdude wrote: ↑Tue Sep 17, 2019 5:53 am Yes definitely looks like chain roller shells. Full strip down required.
- Bofs
- registered user
- Main scooter: Zundapp Betta 500
- Contact:
Just chaincase, could be the thimble off your clutch, in that case it might be a simple case of replacing it.
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Bad Samaritans SC
Warkton Tornado No.1
- registered user
- Main scooter: Lambretta SX200
- Contact:
It really does look like it is part of the duplex drive chain.
You should thoroughly inspect inside for more debris as well as check the existing chain.
If it has a Rolon chain fitted, do not use it again, would be my strong advice.
