spaq disc brake
TED CRUD
Anyone had any success setting one up tried different ways .bot the anti dive twist the backing plate causing the caliper to bind
Smash Ya Pastie
Washington Posse s.c
Picture might help.
I usually replace the tie bar with Rose joints and a bit of threaded bar
TED CRUD
I knew that there was a fix but I couldn't find anything. Do you know the sizes of the joints /bar and bolts
Cheers
Smash Ya Pastie
wrecklessrobbie
Main scooter: li150
That disc brake looks in a low position.
The tie bar looks long.
viewtopic.php?t=24975
The rose joints i bought are like these.
I have however removed by anti dive.
I did not enjoy it. So am just running a standard disc brake.
Robbie
gaz_powell
/\ same here, didnt like it from the off.
Put it to go Cleethorpes and removed as soon as i got back !
The rose joints are M8 and the bar about 40 mm
The picture angle makes it look low - it's not as low as it looks
TED CRUD
Thanks for the help lads, cheers
Smash Ya Pastie
    Users browsing this forum: Baidu [Spider] and 32 guests
