GP tail light bulb blowing
Mrnice71
Hi chaps
Im sick of the rear tail light bulb blowing on my GP 200 TS1 , dont have a problem with any of the other bulbs , is there a fix for this or is just down to vibration ? Wondering if the LED conversion would cure this ? Im running an AC stator ...cheers
johnny650
Main scooter: lambretta 64 li 150 Special
is it the tail light or the stop light filament thats blowing ?
Mrnice71
Tail light Johnny mate
Tractorman
Main scooter: Lambretta li150 special
If it coincides with you using the dip switch it could be that that's faulty. Or maybe a faulty connection that puts the headlight out long enough too blow the back light bulb.
garry inglis
check your earths and you could have a brake in the loom also the led is a lot betteri would also check the rubber boot on the break pedal hasent
come off and the wires pulled out a bit
Daggs
Is this a 12v AC conversion or standard factory set-up.
Mrnice71
Daggs wrote: ↑Thu Sep 27, 2018 7:20 am Is this a 12v AC conversion or standard factory set-up.
Its running a 12 v AC electronic ,daggs
Daggs
In that case, I suspect there's a little too much voltage coming from the reg. and as 'tractorman' said. There is a momentary peak and the lamp filament blows.
Buy yourself a LED conversion bulb, it should cure it.
Mrnice71
Right had rear light off ,cleaned up all terminals & earths ,try that if not LED it is , cheers guys !
warts
Main scooter: honda
Agree it is likely a voltage peak, but if it is caused by vibration, an old trick is to put two or three small dabs of silicone round the metal casing to act as a damper.
    Users browsing this forum: Amazon [Bot] and 2 guests
