Hi chaps
Im sick of the rear tail light bulb blowing on my GP 200 TS1 , dont have a problem with any of the other bulbs , is there a fix for this or is just down to vibration ? Wondering if the LED conversion would cure this ? Im running an AC stator ...cheers
GP tail light bulb blowing
Tractorman
- Main scooter: Lambretta li150 special
If it coincides with you using the dip switch it could be that that's faulty. Or maybe a faulty connection that puts the headlight out long enough too blow the back light bulb.
- garry inglis
- Main scooter: ts1 230 and rb200
check your earths and you could have a brake in the loom also the led is a lot betteri would also check the rubber boot on the break pedal hasent
come off and the wires pulled out a bit
Is this a 12v AC conversion or standard factory set-up.
In that case, I suspect there's a little too much voltage coming from the reg. and as 'tractorman' said. There is a momentary peak and the lamp filament blows.
Buy yourself a LED conversion bulb, it should cure it.
