Easy clutch
dennis
Main scooter: 1 gp 1 special
Any one using one and does it make the clutch that much easier.
10 inch Terror
Xbox live gamer tag: No.
Yes, I’m using them on 2 of my scoots. Well worth the money and effort of fitting them.
Den 08
Main scooter: lambretta Gp 225
Hi 10 inch terror,
How have you fitted the easy clutch is at the clutch arm end or handlebars,any pics? and what one are you using, noticed there’s a few different makes out there.
Sorry for long post.
Struggling to pull lever broken fingers😕taking a long time to recover need to look at options
HxPaul
Beedspeed do them but they're £34.99 plus £4.99 p&p but they include inner and outer cables of the correct length.These are the cheapest I've found but you have to make up you own cables,the price doesn't include p&p - http://www.mdracingproducts.co.uk/unive ... lutch.html
dennis
My friend is trying one but can't get the full pull at crank case end before lever touches handle bar at top,would adjustable levers be an idea?.
HxPaul
It sounds like he's got the cables the wrong way around.
dennis
He's tried both ways,still no joy.
gppaul
Main scooter: GP200
has anybody got pictures of one fitted to a scoot
HxPaul
Minority
Main scooter: Li230 S3
dennis wrote: Wed Sep 05, 2018 11:30 am My friend is trying one but can't get the full pull at crank case end before lever touches handle bar at top,would adjustable levers be an idea?.
I haven't used an "easy clutch", but generally any gearing system that takes less strength to move an object will require more movement at the input end, that's the way gearing works. With the standard Lambretta clutch being susceptible to marginal clearance/pull issues if not setup properly (and made worse with some non standard plate/steel setups causing drag if not careful), I can understand why your friend is having problems. The only solution is to get more pull at the lever by some means.
