Easy clutch
10 inch Terror
- registered user
- Xbox live gamer tag: No.
- Playstation gamer tag: PLEASE!
- Main scooter: Lambretta LI Imola 185
- Contact:
Yes, I’m using them on 2 of my scoots. Well worth the money and effort of fitting them.
Den 08
- registered user
- Main scooter: lambretta Gp 225
- Contact:
Hi 10 inch terror,
How have you fitted the easy clutch is at the clutch arm end or handlebars,any pics? and what one are you using, noticed there’s a few different makes out there.
Sorry for long post.
Struggling to pull lever broken fingers
taking a long time to recover need to look at options
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
Beedspeed do them but they're £34.99 plus £4.99 p&p but they include inner and outer cables of the correct length.These are the cheapest I've found but you have to make up you own cables,the price doesn't include p&p - http://www.mdracingproducts.co.uk/unive ... lutch.html
has anybody got pictures of one fitted to a scoot
Minority
- registered user
- Main scooter: Li230 S3
- Contact:
I haven't used an "easy clutch", but generally any gearing system that takes less strength to move an object will require more movement at the input end, that's the way gearing works. With the standard Lambretta clutch being susceptible to marginal clearance/pull issues if not setup properly (and made worse with some non standard plate/steel setups causing drag if not careful), I can understand why your friend is having problems. The only solution is to get more pull at the lever by some means.
- Information
Who is online
Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 4 guests
