Lambretta Carb Set-ups.....
gerryjunior
Xbox live gamer tag: no
Playstation gamer tag: no
Main scooter: lambretta li 2
rapido 250, af 48 mm big bore, gt 60 x 110 crank ,mammoth head, cyclone gearbox, 30 mil phbh, 40 slide, 70 choke, 130 main, av 268, 70 choke . x 13 needle , breath sweet filter.
kevspeed
dave wheeler wrote:TV175, standard barrel, matched ports, scootopia clubman
24mm dellorto phbl
slide 40
choke 60
pilot 50
atomiser AQ264
needle D22, third notch
main 100
Is this set up running through the airbox,and if so is it a TV2 or a TV3?
Davidsquaredson
Main scooter: Early Eibar Jet 200
Engine: 175, a Li 150 cylinder bored out to 175, no modification to ports.
Exhaust: BGM Clubman
Carb: Dellorto(scootopia) SH2/22
Main jet: 142
Pilot: 50
GP200 slide & atomizer
Smooth rubber elbow and good quality foam filter. (Binned the airbox)
At around-town driving, 1/2-3/4 throttle my if was white with a 123 main, and stayed like that as kept increasing. Not until 140 I started to get colour and at 142 it's perfect. It seams like a huge main jet, but on this primitive carb It's the ratio of atomizer to main that is important.
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
garry inglis
ts230 30mm phbh
main 125
pilot 53
x7 2nd clip
av266
40 slide
60 choke
garry inglis
ts230
30mm vhsh
main 160
pilot 45
dp266
k21 on 2nd
300 float
50 slide
garry inglis
rb200
30mmvhsh
main 155
pilot 55
dp266
k21 on 2nd
50 slide
300 float
garry inglis
ts1 230 with 34mm dellorto
165 main
52 pilot with cd1
dp266
k21 on 2nd
300 float
40 slide
runs great
hat
Main scooter: SX150/ Mugello 186
Mugello 186 top end
Matched ports
Engine SX150
Std crank
46/16 150 li gearbox
Franspeed supertourer
30mm delly phbh open mouthed
120 main
55 pilot
AV268
X7 1st clip
40 slide
Dyno’d @ 18bhp
Just checking the numbers on my TMX27 carb (Imola 186) that I posted on here in 2009. I see posts virtually every day on Faecebook about jetting PHBH carbs and the hundreds (if not thousands) of variations you can come up with between needle, slide and atomiser. Never had those issues with my Mikuni. My TMX jetting worked on day one (pre 2009) and has never been touched, even had it dyno'd without needing any AFR adjustment. One thing I did do though was that I had to remove the power jet (260 main, 50 power jet = 310) as the feed pipe rubbed on something and wore a hole in it, so I temporarily fitted a 310 main and blocked off the power jet. It runs just the same, had that dyno'd too. Also have a Mugello 225 that I could never get to run well on a 26mm PHBH, so much so that I holed the piston after leaning it off too much doing plug chops (maybe the M55 isn't the best place to do plug chops), I didn't have a spare piston but had a TS1 piston and an LTH reed valve and inlet so thought less stick that on. Figured I'd built it correctly but I couldn't get it to start with the PHBH car,b convinced it was that I took the Mikuni off the Imola and tried that, fired up straight away, again not touched the jetting and several years later it's still on there running great on the odd occasion that I do any riding. There's a moral in there somewhere but I've given up trying to convert people years ago.
alcoholic maniacs sc
Hi All,
Lambretta 1970 Gp200 fitted with rebuilt 1968 sx200 engine all standard
1971 Gp200 barrel with 8000kms from new
1971 NOS Dellorto 22 mm, brown original float with standard jets, red topped needle and standard atomiser but with 128 main jet instead of 118.
NOS Lambretta 1960's standard sx200 exhaust complete
no airs coop on frame as 1970's Ancelotti with unmodified GP airbox and BGM fast flow filter.
runs sweet/ drives well/ ticks over all day but under hard acceleration it cuts out above 500- rpm and backfires, then settles down to run sweet at lower revs and cruises well at 40ish. I was told standard atomiser is 1.5mm and I could drill it out to 2mm or 2.5mm will this help?.
