Multimeter setting ????
weller51
Want to check my sil stator as she fires then dies straight away got myself a multimeter set it to ohms I know but what setting to get a correct reading 2m 2ook 20k 2k 200 ?? :?
garry inglis
Set it on 200k and check white to earth should be infinity or nothing red to earth 95 to 110 and green to earth 480 to 515
weller51
Thanks Garry I'll give that a go and see what readings I come up with
garry inglis
red is the pick up and green low tension coil
weller51
Will earthing the wires to the back of the mag housing be ok ???
garry inglis
Yes
weller51
Cool thanks
