Exhaust spraying options
loadedscooterist
Main scooter: lambretta li150 special
Hi All,
I have been reviewing the state of the exhaust on my Li 150 today that I have been slowly restoring and sorting out bits on. I have found out its an AF Rayspeed which is good. However, its state isn't the best a fair bit of the paint has flaked off over the years and the U bend is looking rusty.
I would like to keep the exhaust rather than buy something new but wondered what the best options were for getting it looking half decent again.
Thoughts?
fluff34567
Get it blasted or try paraffin depending on the paint. When paint is off check for cracks on the brackets then use a heatproof spray paint. Decent heat proof paints need to go in the over at about 200c for an hour once it is air dry
Here one I did last week.
Sent from my BND-L21 using Tapatalk
LI150
Main scooter: Series 2 LI150
Just spray in wilko barbecue paint
Grumpy225
Ceramic coat it and forget about it.
Burnside
Main scooter: Lambretta TV200
My Franspeed Race has just rotted through after only 3 years, but that is riding pretty much every day all year round, this winter seemed particularly harsh, it did get a rub down and spray last year, but a couple of knocks on speed bumps haven't helped as that is where it has gone. So I've just ordered another and will be getting this one ceramic coated. I've got BGM clubman on another scooter that I had ceramic coated and that is still in really good nick 4 years later
Outside, maybe, but they corrode from both inside and out.
onthelam
Main scooter: not yet
Loaded. Do you have a pressure washer? For about 40 quid you can buy a water blasting attachment and blast stuff yourself.
Burnside
rosscla wrote: Mon Apr 02, 2018 8:07 pm Outside, maybe, but they corrode from both inside and out.
True although the inside won't be as susceptible to road grime and salt
flipster
Just done mine with this ,
£7 a can ! Couldn’t fit it in my oven so when it was touch dry put it back on and went for a good run to cure ! Sorted !
Cheers.
P.N.D.S.C.
Grumpy225
This coating is about 13 years old on the original Innocenti exhaust
It's very dirty here but you get the idea of how it holds up.
