T5 running crap
soulboy
All stock apart from
Pipe when it does start it races all over place and takes ages to fall on to tick over lost count how many times carb as been apart anyone help cheers
mick1
Main scooter: Li Avanti 225
sounds like an air leak.
Maybe worth investing in a leak test kit.
Wouldn't go too far on it till it's sorted.
soulboy
Just ordered a brand new carb
mick1
air leak could be any where........cylinder head, base, seals, casings, etc
mick1 wrote:sounds like an air leak.
Good advice
soulboy
Its got brand new gaskets and a new fly side oil seal even put head gasket on ..it will fall off the revs after a short time but rev it again and its all revs all over place again
GTFOMWSC
soulboy wrote: Sun Mar 04, 2018 8:46 pm Its got brand new gaskets and a new fly side oil seal even put head gasket on ..it will fall off the revs after a short time but rev it again and its all revs all over place again
maybe an uneven carb body suffice onto the block(worn) had a P2 doing similar it was Diablo who sussed it at about 11pm after a few hours of head scratching.Try another carb body with all your jetting in it it may or may not work
the man don't give a f@@k
HxPaul
mick1 wrote: Sun Mar 04, 2018 5:45 pm air leak could be any where........cylinder head, base, seals, casings, etc
If its non of these,check that your carb hasn't been overtightened and caused it to deform along the bottom causing it to draw air in.
GTFOMWSC
HxPaul wrote: Sun Mar 04, 2018 10:41 pm
paul d
Main scooter: T5 172 Tv 240
Has the gear oil level dropped? Also, sometimes an overtightened carb body can prevent the slide fully returning. A worn throttle cable can stop the slide too resulting in the high revs you describe.
