All stock apart from
Pipe when it does start it races all over place and takes ages to fall on to tick over lost count how many times carb as been apart anyone help cheers
T5 running crap
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
Good advicemick1 wrote:sounds like an air leak.
Maybe worth investing in a leak test kit.
Wouldn't go too far on it till it's sorted.
- Main scooter: t5 172 and a bit more
Its got brand new gaskets and a new fly side oil seal even put head gasket on ..it will fall off the revs after a short time but rev it again and its all revs all over place again
- GTFOMWSC
- Main scooter: GP230 Super Monza CS Tuned
maybe an uneven carb body suffice onto the block(worn) had a P2 doing similar it was Diablo who sussed it at about 11pm after a few hours of head scratching.Try another carb body with all your jetting in it it may or may not work
the man don't give a f@@k
- Main scooter: T5 172 Tv 240
Has the gear oil level dropped? Also, sometimes an overtightened carb body can prevent the slide fully returning. A worn throttle cable can stop the slide too resulting in the high revs you describe.
