and then me balls fell out
Minority
Main scooter: Li230 S3
I made up this little tool to help, still not easy to do with layshaft fitted in casing, but it makes it a bit easier :D
Image20170923_175516 by John Stacey, on Flickr
garry inglis
That's looks just the same as my two screwdrivers lol nice one minority
johnny650
Main scooter: lambretta 64 li 150 Special
Minority wrote: Sun Sep 24, 2017 11:28 am I made up this little tool to help, still not easy to do with layshaft fitted in casing, but it makes it a bit easier :D
nice tool Minority.......... I like home made tools but it wouldn't fit in the case with the layshaft fitted unfortunately. :cry:
Minority
It does, just (like most things in the lambretta gearbox/clutch/kickstart area, they just fit). I used it to change the detent spring between the two ball bearings. I foolishly changed to an MB up-rated spring at one stage which made the changing gears painful (literally), so I wanted to change the spring back to standard. I made this tool to achieve this without stripping the back hub and layshaft out of the casing after spending hours and much swearing trying to do it with just my hands (no headbutting involved :) )
This nearly drove me nuts on my last motor. I had a tight spot on the box in third and fourth which wasn't that apparent till the box was assembled. I had it in and out a dozen times before I eliminated it by bending the yoke, but I must have pushed it past 4th and popped the balls out every other time...
Trevor Emerton used to sell a very simple tool for that job. Not sure if he's on here.
https://www.facebook.com/beverleylambre ... lds.bler.1
