AC vs DC stators and electronic kits.
fluff34567
Cheers all.. had a look on the mb site and should be clear.
kejj
The only thing I noticed on the full DC as a down side is
1. The gel batteries need topping up since they loose power over time. If not then they will run empty and won't recharge
2. Even with the ignition off the battery is live and if you lock the front brake with a grip lock the brake light will be on. (if you have it connected to rear light)
3. You need to really isolate all terminals. The smallest contact short-circuits the bike
Skickat från min F3311 via Tapatalk
________________________
http://tv175.wordpress.com/
purple_pill67
Main scooter: Jet200
Iirc if your battery ever fails, just earth one of the yellows from the wassel to go back to ac to get you going again
fluff34567
Oh that's good.. any idea which one?
Monty
fluff34567 wrote: Mon Aug 28, 2017 8:09 am Oh that's good.. any idea which one?
doesn't really matter but when I add the extra wire I use a black or blue wire (whatever I have that wont get mixed up with the white red or green) That's the one to earth. I think you are all overcomplicating this. I haven't used gel batteries but always use the small alarm wet acid Batteries. I use the ignition to isolate everything until I switch to lights. I did do a mates who used a Cam Lam LED fuel level sensor and if he parked up with low fuel it would drain so I fitted a relay that took its coil power from the lights, bit of a phaff but worked fine. Yes I killed one battery but I left the lights on when I locked it in the shed :evil: the bike still ran had good lights but it would not hold a charge for more than a few minuets with the engine off. It still functioned as a smoother as a Capacitor does. I know some charges can recover these units but it cost more than a new battery
purple_pill67 wrote: Sat Aug 26, 2017 6:48 pm Iirc if your battery ever fails, just earth one of the yellows from the wassel to go back to ac to get you going again
You also need to have a regulator fitted rather than the rectifier and be able to connect that to the loom if you want to do a roadside switch like this.
rosscla wrote: Mon Aug 28, 2017 1:59 pm............
Good point, carry the old AC regulator in the tool box or better still, buy a cheap Wassel clone such as http://www.ebay.co.uk/itm/Universal-12V ... 0005.m1851
