Got a melted piston on my gp150 so decided to put a kit on it, don't want to change the crank so anyone got any recommendations please I haven't got a massive budget at the moment either
Sent from my D6603 using Tapatalk
Recommend 175 kit
Scooterdude
- Main scooter: Lambretta LI 125 S3
If your on a limited budget why not look at the Gori 200 kit? Seems decent and comes with a quality piston.
Tractorman
- Main scooter: Lambretta li150 special
If you decide on a re-bore get it done somewhere that knows what there doing. I had one done at a local motorcycle dealer and it was a nightmare they some how managed to get the bore right at the top and bottom but narrower in the middle
I took it to Chiselspeed and they sorted out.
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
+1. should come in well under £300.hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
Not saying it's a better option, just an option.
Off the top of my head and using Scooter Restorations- Piston say £40; Head say £30; Rebore say £40; gaskets £5. Up the main jet a tad (assume you're using the standard 22mm carb?)
bore cylinder to 3.5 thou in old money.
Nice load of hot/cold cycles for running in and away you go.
Scootering since 1968.
bristolmod
P.S. Make sure the piston is the 175 CONVERSION PISTON, not an ordinary TV175 piston.
- HxPaul
- Main scooter: lambretta Li 150
If you decide to put a kit on it,you cant do a lot better than fit a Casa 185.No need to change the crank although I've got one fitted on my series 2 with a Mec crank. https://www.riminilambrettacentre.com/e ... t-185.html
hendy
- Main scooter: lambretta li 125
Yes, WELL under £300. £150 quid for a very good tune.bristolmod wrote:+1. should come in well under £300.hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
Cheers Chris sounds like a planbristolmod wrote:+1. should come in well under £300.hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
Ryskie
- Main scooter: Lambretta GP
PJ Engineering in Wednesfield could sort the re-bore and probably sort a piston as well for you mate.dazblakey wrote:Cheers Chris sounds like a planbristolmod wrote:+1. should come in well under £300.hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
- Information
Who is online
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 19 guests
