Recommend 175 kit
dazblakey
Got a melted piston on my gp150 so decided to put a kit on it, don't want to change the crank so anyone got any recommendations please I haven't got a massive budget at the moment either
Sent from my D6603 using Tapatalk
Scooterdude
If your on a limited budget why not look at the Gori 200 kit? Seems decent and comes with a quality piston.
hendy
Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
Not saying it's a better option, just an option.
Tractorman
If you decide on a re-bore get it done somewhere that knows what there doing. I had one done at a local motorcycle dealer and it was a nightmare they some how managed to get the bore right at the top and bottom but narrower in the middle :!: I took it to Chiselspeed and they sorted out.
bristolmod
hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
+1. should come in well under £300.
Off the top of my head and using Scooter Restorations- Piston say £40; Head say £30; Rebore say £40; gaskets £5. Up the main jet a tad (assume you're using the standard 22mm carb?)
bore cylinder to 3.5 thou in old money.
Nice load of hot/cold cycles for running in and away you go.
Chris
Scootering since 1968.
bristolmod
P.S. Make sure the piston is the 175 CONVERSION PISTON, not an ordinary TV175 piston.
Chris
HxPaul
If you decide to put a kit on it,you cant do a lot better than fit a Casa 185.No need to change the crank although I've got one fitted on my series 2 with a Mec crank. https://www.riminilambrettacentre.com/e ... t-185.html
hendy
Right side of £300.
Chris
Yes, WELL under £300. £150 quid for a very good tune.
dazblakey
Right side of £300.
Chris
Cheers Chris sounds like a plan
Ryskie
dazblakey wrote:
Right side of £300.
Chris
PJ Engineering in Wednesfield could sort the re-bore and probably sort a piston as well for you mate.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
