Oil leak...
Timbo
Where the exhaust pipe stud goes into the main casing the thread is exposed a little underneath the casing resulting in the oil leaking. I've not taken the cover off yet but looking for a quick fix and I'm thinking welding is not an option. As I said I'm looking for a quick fix.
holty
Main scooter: lambretta gp
I presume you mean the stud that goes through the side case and into the engine case, in which case the gasket should seal the 2 halves together, maybe a cork gasket might seal it for you, also fit the stud with stud lock to lock and seal it in place
joespeed
are you talking of a barrel/cylinder stud or the the 8mm thread under the crankcase or the two crankcase side 8mm studs?
Timbo
The end of the tail pipe, the longer stud. I can see its thead under the main casing and that's where the oil is leaking from.
joespeed
jb weld or belzona is a good repair but no substitute for weld
mick1
Main scooter: Li Avanti 225
That's lowest point of the engine so not necessarily where the leak is....
Timbo
Point taken Mick but I can see the hole and the thread of the stud. Someone has suggested that white plumbers tape so will give that a try.
HxPaul
Thats usually the stud that pulls out,I have a case that has done that.What I've done is remove the side case and helicoil the thread.Its resulted in a permanent and strong repair.
Timbo
I've used that plumbers white tape stuff for leaks, will see if it works.
fluff34567
Use some liquid gasket on the stud to seal the hole.
    Users browsing this forum: Google [Bot] and 0 guests
