Oil leak...
Timbo
- Main scooter: SX200 and GP230 RT
Where the exhaust pipe stud goes into the main casing the thread is exposed a little underneath the casing resulting in the oil leaking. I've not taken the cover off yet but looking for a quick fix and I'm thinking welding is not an option. As I said I'm looking for a quick fix.
holty
- Main scooter: lambretta gp
I presume you mean the stud that goes through the side case and into the engine case, in which case the gasket should seal the 2 halves together, maybe a cork gasket might seal it for you, also fit the stud with stud lock to lock and seal it in place
- HxPaul
- Main scooter: lambretta Li 150
Thats usually the stud that pulls out,I have a case that has done that.What I've done is remove the side case and helicoil the thread.Its resulted in a permanent and strong repair.
fluff34567
Use some liquid gasket on the stud to seal the hole.
