dirty trousers
Stokie wrote:Am I still OK using the Vaseline ?
What ever floats your boat flower.. :frog:
I think that could be a good look, but never let your bird catch you wearing her stockings
:o :mrgreen:
J1MS
oggy wrote:I have wot i believe to be a yam /mb master clylinder that leaks on my strides from inside the lever part ,how easy to cure as never had one . Cheers. :D
The master cylinder is a simple piece of kit to strip down, the plunger that applies the braking pressure to the fluid has a rubber seal that can leak. The master cylinder comes apart usually by removing a circlip that sits in the housing behind the lever... Once the lever is removed it can be taken apart (you will have to drain the brake fluid first)... The circlips can be a little awkward to get out but with the right circlip pliers is not to dificult....
If you know the make and model there are service kits available that contain all the new parts necessary to fully service or repair...
oldbiker
How to repair was answered on you other post ("master cylinder" posted july 17)
this is a picture of what you get in a typical master cylinder repair kit
ebay item number 400023234900.jpg (6.81 KiB) Viewed 1256 times
the ebay item number will take you to pamotorcycles, however the picture is for a tzr master cylinder, which may not be the correct item for you.
just about any yam bits have a part number on them, this should help you to identify the bike that it came from
    Users browsing this forum: Google [Bot] and 7 guests
