jet 200
Fruitjuice
Later Servettas had a 20mm Dell'orto carb instead of the Italian 22m, worth upgrading to this...
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
Davidsquaredson
Main scooter: Early Eibar Jet 200
ducksta wrote:
10 inch Terror wrote:A SIL stage 4 barrel with decent piston upgrade, skimmed head, a decent clubman pipe and up jetted carb to suit and for under £200-225 you'd see a worthwhile increase in performance.
Think the above is about right not too much retaining the standard look
That's essentially what I had before I put a GT kit on. Good for 100 kmph. You'll spend 2-3x more for then next 10 -20 kmph.
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Davidsquaredson
That's my Jet200 next to my Rally. Doing some wrenching in the spring sunshine today. If you can find an Eibar it's pretty close to an Italian SX. Image
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
