Rayspeed 6 plate clutch
garry inglis
Image just Been for a 20 mile run and no slipping slight adjustment needed but we'll pleased
alanscottj
Mine took a bit to set up and find 'the sweet spot' but once I found it and it was adjusted just right, perfect :D
shamrockexpress
what about the readspeed 6 plate i was thinking one of these as you can use std plates if you are caught short!!!!!
10 inch Terror
Xbox live gamer tag: No.
I found my AF Race excellent but the Road version was awful. I spent hours fettling it to get it to work. It had a horrible feel even with correctly routed quality nylon lined clutch cable. I swapped it out for a BGM Super Strong in the end. There's clutches seem to go under the radar. It's in my RB20 and it's spot on.
garry inglis
Well if there are no more race clutches it'll have to be bgm or lth 7 plate I think I'll get some spairs just in case
