Cone steering bearing upgrade.
10 inch Terror
Xbox live gamer tag: No.
Hi all,
I remember seeing somewhere a nice steering upgrade for Lambrettas using cone bearings rather than the traditional type. I'm sure Taffspeed made them But I can't find any via a google search. Could anyone point me in the right direction please. Thanks in advance Pete.
storkfoot
I think I have seen them on Facebook but I am sure, if you phone the Taffspeed number on their website, they'll be able to help you.
dansacred
Main scooter: li 150 series 3
eBay
Eibar
Main scooter: Eibar TS1 1966
Terr frankland facebook
potato
Donnie
seen them but dont get it
Donnie.
fairspares
Donnie wrote:seen them but dont get it
Me either , most of the weight of the frame etc is on the lower bearing which is where an upgrade should be done.
holty
Main scooter: lambretta gp
the bottom bearing has much bigger balls so is stronger, plus you can always add lots of balls and no cage, top however is made with very small balls so isnt as strong, probably aimed at scooters with a good front disc brake, and riders who ride faster,braking hard from high speed will put some load on them little bearings, as do bumpy roads and pot holes, its something i might use in the future
Donnie
holty wrote:the bottom bearing has much bigger balls so is stronger, plus you can always add lots of balls and no cage, top however is made with very small balls so isnt as strong, probably aimed at scooters with a good front disc brake, and riders who ride faster,braking hard from high speed will put some load on them little bearings, as do bumpy roads and pot holes, its something i might use in the future
really?
Donnie.
fluff34567
On frankland page I only see a bearing kit for the fork links.
fluff34567
Found it...... Image £58 on ebay
