Oil seal removal [emoji24]
randylearner
Main scooter: lambretta1li25
Evening all.
I'm pulling my hair out,
Trying to remove oil seal and can't budge the thing.
Got impact driver and broken a few pieces now. Had heat on it.
Started drilling pop out of seal
What's next
https://www.flickr.com/photos/151493805 ... ed-public/
You need to remove the for screws and the oil seal plate first......?
randylearner
Hello drunk photo attached, on Flickr
randylearner
That's what I'm trying to get off. Bloody thing won't budge.
fairspares
if you cant budge the 4 screws /bolts with a screwdriver or impact, get a long dot punch and tap the corner of the slot anti clockwise carefully or even a thin bar grind to fine point , this will loosen the screws then they will just come out .
hendy
randylearner
fairspares wrote:if you cant budge the 4 screws /bolts with a screwdriver or impact, get a long dot punch and tap the corner of the slot anti clockwise carefully or even a thin bar grind to fine point , this will loosen the screws then they will just come out .
Will have a try. Fingers crossed.
randylearner
Cheers hendy
Chris in Margate
Good bladed screwdriver. If it has a flat near the handle, even better. Grip this with adjustables or mole grips and keep strIking the handle end of the driver firmly whilst trying to turn screwdriver with grips.
bazza3004
Always managed to get them out with a decent impact driver myself . well once i had the impact driver set to the correct rotation :)
    Users browsing this forum: Semrush [Bot] and 8 guests
